Microsoft Wireless Mobile Mouse 3500
£20.74
Colours:
36 in stock
Delivery:
Standard: 1-3 working days
Key features
  • BlueTrack technology
  • Plug-and-go Nano transceiver
  • On/off switch
  • Comfortable in either hand
  • Recommended Use: Leisure, Mobile
  • Type: Mouse
  • Wired / Wireless: Wireless
  • Colour: Lochness grey
  • Compatibility: PC
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £24.23
Save £1.50
You'll appreciate how this wireless mobile mouse comfortably fits your hand and your mobile lifestyle. Use it just about anywhere, even on a rough park bench or your living room carpet, relying on Microsoft BlueTrack Technology.
When it's time to pack up and go, you'll hardly notice the tiny transceiver. Keep it plugged into the USB port, or stow it in the bottom of the mouse for travel. Keep using your mouse for up to eight months with a single battery, and rely on the power indicator to tell you when it's time to replace it.
Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
Plug-And-Go Nano Transceiver
Leave the Nano Transceiver plugged in when you're on the go, or stow it in the mouse.
8-Month Battery Life
Use your mouse for up to eight months without having to change batteries. Battery status indicator tells you when battery power is low.
On/Off Switch
Conserve battery power by turning off your mouse when not in use.
Comfortable in Either Hand
Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Product Description Microsoft Wireless Mobile Mouse 3500 for Business - mouse - 2.4 GHz - lochness grey
Device Type Mouse
Connectivity Technology Wireless - 2.4 GHz
Colour Lochness grey
Orientation Right and left-handed
Wireless Receiver USB wireless receiver
Movement Detection Technology Optical
Buttons Qty 3
Movement Resolution 1000 dpi
Features Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
OS Required Microsoft Windows 7, Windows 8, Microsoft Windows RT, Windows 8.1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Microsoft Wireless Mob...
£20.74
