Experience the incredible intensity, precision and comfort of the Xbox Wireless Controller. Impulse triggers deliver fingertip vibration feedback, so you can feel every jolt and crash in high definition. Responsive thumbsticks and an enhanced D-pad provide greater accuracy.
Compatible with select devices and operating system versions; learn more at xbox.com/controller-compatibility. Battery life varies significantly with headsets, additional accessories, usage, and other factors. Testing conducted by Microsoft using standard AA batteries in preproduction units. Button mapping available via Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11; app for Windows requires compatible USB-C cable (sold separately).
Windows 10/11: Requires Bluetooth, compatible USB-C® cable, or Xbox Wireless adapter. Each sold separately. Android, iOS, & Bluetooth: Select devices and versions. Some functionality not supported. Software download may be required via Windows PC or console. See xbox.com/controller-compatibility. Use with controller compatible games. You must accept the Warranty & Agreement at xbox.com/warranty and Software License Agreement at xbox.com/slt.
Product Description | Microsoft Xbox Wireless Controller - gamepad - wireless - Bluetooth | Product Type | Gamepad | Connectivity Technology | Wireless - Bluetooth | Controls | D-pad, 2 thumb sticks, triggers, Share button | Features | Headset port, Xbox Wireless support, textured grip | Colour | Electric volt | Designed For | PC, Microsoft Xbox One, Android, iOS, Microsoft Xbox Series S, Microsoft Xbox Series X |
General | |
System Requirements | |
OS Required | Android, Apple iOS, Windows 10 |
Miscellaneous | |
Required Battery | AA type |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
