Mophie InvisibleShield Glass+ Privacy - iPhone 6/6s/7/8 Case...
Mophie InvisibleShield Glass+ Privacy - iPhone 6/6s/7/8 Case Friendly Screen
Key features
  • Two-Way, Side-View Privacy:High-quality tempered glass is treated with a two-way privacy filter that provides full-screen privacy when viewed from the side
  • Shatter Protection: Glass+ Privacy features Ion Matrix technology, the most advanced impact and shatter protection available
  • Smudge Resistant: Its long-lasting, oil-resistant technology helps prevent fingerprint smudges to keep your screen pristine
  • Easy Application: Smart EZ Apply tabs make application bubble free. Simply align the adhesive, press it, and watch as Glass+ Privacy does the rest
Product codes
The toughest glass screen protection now protects your screen from curious eyes.
  • Shatter Protection: Glass+ Privacy features Ion Matrix™ technology, the most advanced impact and scratch protection available.
  • Two-Way, Side View Privacy: High-quality tempered glass is treated with a two-way privacy filter that provides full-screen privacy when viewed from the side.
  • Smudge Resistant: Its long-lasting, oil-resistant technology prevents fingerprint smudges to help keep your screen pristine.
  • Easy Application: Smart EZ Apply® tabs make application bubble free. Simply align the adhesive, press it, and watch as Glass+ Privacy does the rest.
  • A Warranty You Can Count On: A limited lifetime warranty means if your Glass+ Privacy gets worn or damaged, ZAGG will replace it for the life of your device.
Product Description ZAGG InvisibleShield Glass+ Privacy - screen privacy filter
Product Type Screen privacy filter
Intended for Mobile phone
Protection Scratch-resistant, impact protection, smudge-proof, shatterproof
Designed For Apple iPhone 6, 6s, 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Mophie InvisibleShield...
