Mophie InvisibleShield Glass Contour - iPhone 7/8 Screen - Black
Key features
  • Precisely curved edges fit your screen perfectly for premium, edge-to-edge protection
  • High-quality tempered glass delivers maximum image clarity, an ultra-smooth feel, and remarkable touch sensitivity
  • Smart EZ Apply tabs make applying your Glass Contour simple and accurate
  • The Limited Lifetime Warranty says that if your Glass Contour ever gets worn or damaged, we will replace it for the life of your device
  • 9H Hardness
Product codes
Tempered Glass screen protector with Maximum Clarity + Ultra-smooth Protection. Patented EZ apply tabs make application simple and bubble-free.
Protection that’s engineered to disappear.
  • Precisely curved edges fit your screen perfectly for premium edge-to-edge protection.
  • High-quality tempered glass delivers maximum image clarity, an ultra-smooth feel and remarkable touch sensitivity.
  • With a limited lifetime warranty, if your Glass Contour ever gets worn or damaged, ZAGG will replace it for the life of your device.
  • Smart EZ Apply® tabs make applying your Glass Contour simple and accurate.
Product Description ZAGG InvisibleShield Glass Contour - screen protector
Product Type Screen protector
Intended For Mobile phone
Protection Scratch-resistant
Product Material Tempered glass (9H)
Colour Black
Designed For Apple iPhone 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Mophie InvisibleShield...
