Mophie Wireless Charging Pad Optimized for iPhone 8, iPhone 8...
FREE DELIVERY
Mophie Wireless Charging Pad Optimized for iPhone 8, iPhone 8 Plus and iPhone X
£79.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
The new standard for high-speed wireless charging
Working together, mophie and Apple created the most convenient charging experience possible built to comply with medium power Qi wireless charging standards. mophie, the leader in portable power collaborated to integrate the latest Apple technology optimized for the iPhone to deliver safe, fast-charging speeds with up to 7.5W of power.
mophie makes charging your iPhone easier than ever. This wireless charging pad includes the latest Qi technology and delivers up to 7.5W fast-charging speeds to your phone on contact. The non-slip finish ensures perfect placement and the included wall adapter means you get everything you need to get charging right in the box.
mophie has created the most convenient iPhone charging experience possible, built to comply with Qi wireless charging standards. mophie, the leader in portable power collaborated to integrate the latest technology optimized for the iPhone to deliver safe, fast-charging speeds with up to 7.5W of power to compatible devices.
Wireless technology optimized for the iPhone
Designed to work seamlessly with the wireless technology built into the iPhone, the mophie wireless charging base charges your iPhone on contact. Ultra-fast response time activates charging immediately while maintaining the full functionality of your phone and access to your favorite features.
Small, compact, and a non-slip grip
This minimal low-profile design fits perfectly wherever you choose to charge at home or the office. A 360-degree, rubberized, non-slip TPU coating protects and keeps your iPhone properly aligned while charging. In addition, the die cast metal inner structure is electroplated, creating a stable, sturdy platform that stays where you want it – just drop and charge.
Fully compatible with mophie charge force accessories
The mophie wireless charging base is optimized to work with iPhone, but it will also wirelessly charge any mophie case with wireless charging, as well as other Qi-compatible wireless devices
Safe and worry-free charging
When connected to your device, smart charging circuitry communicates with your device to determine the perfect amount of power it needs for a safe, quick charge. Fail-safe circuitry prevents over-charging and controls temperature to prevent overheating.
  • Ultra-fast response time: Immediately starts charging on contact
  • Low standby current: Ensures minimal power draw when idle
  • Foreign object detection: Communicates with the device, ensuring that power is only sent to compatible wireless devices
Everything you need, right in the box
  • Wireless charging base
  • Wall adapter with 1.5m tethered cable
  • Quick start guide
Product Description mophie wireless charging base
Wireless Charging Standards Qi
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Mophie Wireless Chargi...
£79.99
