Motorola AP-7522 Indoor 802.11AC
Key features
  • Comprehensive features serve as a multi-role network access point
  • Antenna designed to bring reception to the outer edge
  • Easy and cost-effective movement to 5th gen WLAN standards
Product codes
This versatile dual radio access point can operate as an in-line sensor for client location awareness and security threat analysis or can be used as a dedicated full-time dual band sensor - an ideal tool when building a multi-role, secure network. The versatility of the AP 7522 also means cost savings without sacrificing quality.
Extreme Networks AP 7522 - radio access point
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
16.5 cm x 18 cm x 4.1 cm
820 g
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Motorola AP-7522 Indoo...
