Exceptional camera systems, vibrant displays, next-gen performance, and striking designs. The new motorola edge 20 family pushes the boundaries of what your smartphone can do.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Motorola Moto E20 - coastal blue - 4G smartphone - 32 GB - GSM | Product Type | 4G smartphone | Display | LCD display - 1600 x 720 pixels - 6.5" - 269 ppi - 20:9 - IPS | Processor | Unisoc T606 / 1.6 GHz (8-core) | Memory | RAM 2 GB / 32 GB | Supported Memory Card | microSDXC slot - up to 1 TB | Operating System | Android 11 (Go edition) | Main Camera | 13 Megapixel - f/2.2 - focus: automatic | Second Camera | 2 Megapixel - f/2.4 - depth camera | Front Camera | 5 Megapixel f/2.2 | Service Provider | Not specified | SIM Card | Dual-SIM - nano SIM | Wireless Interface | Wi-Fi, Bluetooth | Security Devices | Fingerprint reader | Connectors | 3.5 mm headset jack, USB-C | Colour | Coastal blue | Dimensions (WxDxH) | 75.5 mm x 8.5 mm x 164.8 mm | Weight | 184 g | SAR | 1.8 W/kg (body), 1.17 W/kg (head) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 75.5 mm |
Depth | 8.5 mm |
Height | 164.8 mm |
Weight | 184 g |
Body Colour | Coastal blue |
Body Material | Plastic |
SAR Value | 1.8 W/kg (body), 1.17 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Intelligent Assistant | Google Assistant |
Navigation | GPS, A-GPS, GLONASS, Galileo |
SIM Card Type | Nano SIM |
SIM Card Qty | Dual-SIM |
Input Device | Multi-touch |
Communications | |
Data Transmission | LTE |
Wireless Interface | IEEE 802.11a/b/g, Bluetooth 5.0 |
Phone Features | |
Sensors | Accelerometer, ambient light sensor, proximity sensor |
Additional Features | Notification LED, Quick gestures, Google Assistant Button |
Processor | |
Type | Unisoc |
Processor Number | T606 |
Clock Speed | 1.6 GHz |
Processor Core Qty | 8-core |
Memory | |
RAM | 2 GB |
Internal Memory Capacity | 32 GB |
Supported Flash Memory Cards | microSDHC, microSD, microSDXC - up to 1 TB |
Front Camera | |
Sensor Resolution | 5 Megapixel |
Lens Aperture | F/2.2 |
Pixel Size | 1.12 µm |
Special Effects | HDR |
Camera Modes | Pro mode, Beautification mode, portrait mode |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps |
Main Camera | |
Sensor Resolution | 13 Megapixel |
Focus Adjustment | Automatic |
Camera Modes | Panorama, Professional mode, portrait mode, Night Vision |
Light Source | LED flash |
Features | Phase Detect Auto-Focus (PDAF), AI Dual camera, High-res zoom |
Second Camera | |
Sensor Resolution | 2 Megapixel |
Lens Aperture | F/2.4 |
Pixel Size | 1.75 µm |
Functions | Depth camera |
Display | |
Type | LCD display |
Technology | IPS |
Diagonal Size | 6.5" |
Display Resolution | 1600 x 720 pixels |
Display Format | HD+ |
Pixel Density | 269 ppi |
Aspect Ratio | 20:9 |
Features | Max Vision display |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 4000 mAh |
Run Time Details | Standard usage: up to 40 hrs |
Miscellaneous | |
Compliant Standards | IP52 |
Included Accessories | SIM card removal tool, USB-C cable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
