Set your imagination free with moto e30. The 48MP triple camera system captures images that are sharp and bright in any light. Then, view your photos and videos on a fluid 6.5" 90 Hz Max Vision HD+ display. The 5000 mAh battery powers a custom octa-core processor, to deliver responsive performance.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at BT you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Motorola Moto E30 - mineral grey - 4G smartphone - 32 GB - GSM | Product Type | 4G smartphone | Display | LCD display - 1600 x 720 pixels - 6.5" - 268 ppi - (90 Hz) - 20:9 - IPS | Processor | Unisoc T700 / 1.8 GHz (8-core) | Graphics Accelerator | ARM Mali-G52 | Memory | RAM 2 GB / 32 GB | Supported Memory Card | microSDXC slot - up to 1 TB | Operating System | Android 11 (Go edition) | Main Camera | 48 Megapixel - f/1.79 - focus: automatic | Second Camera | 2 Megapixel - f/2.4 - depth camera | Third Camera | 2 Megapixel - f/2.4 - macro camera | Front Camera | 8 Megapixel f/2.0 | Service Provider | Not specified | SIM Card | Dual-SIM - nano SIM | Wireless Interface | Wi-Fi, Bluetooth | Security Devices | Fingerprint reader | Connectors | 3.5 mm headset jack, USB-C | Protection | Splash-resistant | Colour | Mineral grey | Dimensions (WxDxH) | 75.6 mm x 9.1 mm x 165.1 mm | Weight | 198 g | SAR | 1.29 W/kg (body), 0.26 W/kg (head) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Width | 75.6 mm |
Depth | 9.1 mm |
Height | 165.1 mm |
Weight | 198 g |
Body Colour | Mineral grey |
Body Material | Plastic |
SAR Value | 1.29 W/kg (body), 0.26 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Intelligent Assistant | Google Assistant |
Navigation | GPS, A-GPS, GLONASS, Galileo |
SIM Card Type | Nano SIM |
SIM Card Qty | Dual-SIM |
Input Device | Multi-touch |
Communications | |
Data Transmission | LTE |
Wireless Interface | IEEE 802.11a/b/g, Bluetooth 5.0 |
Phone Features | |
Sensors | Accelerometer, ambient light sensor, proximity sensor |
Additional Features | Notification LED, Quick gestures, Google Assistant Key |
Processor | |
Type | Unisoc |
Processor Number | T700 |
Clock Speed | 1.8 GHz |
Processor Core Qty | 8-core |
Graphics System | |
Memory | |
RAM | 2 GB |
Internal Memory Capacity | 32 GB |
Supported Flash Memory Cards | microSDHC, microSD, microSDXC - up to 1 TB |
Front Camera | |
Sensor Resolution | 8 Megapixel |
Lens Aperture | F/2.0 |
Pixel Size | 1.12 µm |
Special Effects | HDR |
Camera Modes | Pro mode, portrait mode, Face Beauty |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps, 1280 x 720 (720p) at 30 fps |
Features | Snap in video recording |
Main Camera | |
Sensor Resolution | 48 Megapixel |
Lens Aperture | F/1.79 |
Pixel Size | 0.8 µm |
Focus Adjustment | Automatic |
Camera Modes | Panorama, Pro mode, portrait mode, Face Beauty, Night Vision, Macro Vision |
Light Source | LED flash |
Features | Phase Detect Auto-Focus (PDAF), AI Dual camera, Quad Pixel technology, High-res zoom, 4-in-1 to 1.6µm pixel, Snap in video recording |
Second Camera | |
Sensor Resolution | 2 Megapixel |
Lens Aperture | F/2.4 |
Pixel Size | 1.75 µm |
Functions | Depth camera |
Third Camera | |
Functions | Macro camera |
Display | |
Type | LCD display |
Technology | IPS |
Diagonal Size | 6.5" |
Display Resolution | 1600 x 720 pixels |
Display Format | HD+ |
Pixel Density | 268 ppi |
Aspect Ratio | 20:9 |
Refresh Rate | 90 Hz |
Features | Max Vision display |
Connections | |
Connector Type | USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 5000 mAh |
Run Time Details | Standard usage: up to 40 hrs |
Miscellaneous | |
Compliant Standards | IP52 |
Included Accessories | SIM card removal tool, USB-C cable, 10W charger |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
