MSI B250M MORTAR ARCTIC Intel B250 S1151 DDR4 USB3.1 M.2 M-ATX
Key features
  • Personalize your gaming rig
  • Stay cool while gaming
  • Your in-game advantage
  • Be the first on the battlefield
  • Immerse yourself into virtual worlds
  • Sound, that pulls you into the game
  • Dominate the game with the low latency
  • Amazing memory performance
  • Designed for limitless tuning
  • Maximize your USB device performance
  • Built on everlasting quality
Product codes
Featuring heavy plated heat sinks and fierce looks, MSI arsenal gaming motherboards are packed with gaming features for a refined gaming experience. Customize and set up your own color scheme with RGB Mystic Light sync. Select any of the colors from the palette, using your smartphone, to match your system style. Bored of the same colors? Simply change the complete look of your system fast!
Product Description MSI B250M MORTAR ARCTIC - motherboard - micro ATX - LGA1151 Socket - B250
Product Type Motherboard - micro ATX
Chipset Type Intel B250 Express
Processor Socket 1 x LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4
Storage Ports 6 x SATA-600, 1 x M.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen1 1 x USB-C Gen 1 + 3 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI B250M MORTAR ARCTI...
