MSI B350M GAMING PRO AM4 DDR4 PCIe M.2 USB3.1
Key features
  • Stay cool while gaming
  • Your in-game advantage
  • Be the first in the battlefield
  • Sound that pulls you into the game
  • Dominate the game with low latency
  • Amazing memory performance
Product codes
B350M GAMING PRO
Serious gaming
1DVI & VGA Port
2HDMI Port
3GAMING LAN
4USB 3.1 Type-A
5Premium audio jacks
MSI B350M MORTAR overview
6Gaming red PCB print design
Stunning looks
7Gaming heatsinks
Great cooling, gaming themed
8DDR4 Boost
Optimized traces and isolated memory circuitry
9PCI-E Steel Armor
Protecting VGA cards against bending and EMI
10Turbo M.2
NVMe support, up to 32 Gb/s using PCI-Express Gen3 x4
11Audio Boost
Optimized gaming audio using best components
12Click BIOS 5
A gamers BIOS
Personalize your Gaming Rig
Connect external RGB strips and sync other RGB capable gear to set up your own color scheme using only 1 application: Mystic Light Sync. Select any of the colors from the palette using your smartphone or the MSI Gaming App to match your system style. Feel like using a different color? Completely change the look of your system in 1 second!
Mystic Light Sync logo
Customize colorsCustomize effectsMystic Light AppMystic Light Extension
Works with certified Mystic Light Sync products:
Mystic Light vendors
Fully controllable fan headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
 Fan Headers
Fan controlFan Headers
Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills.
1 second overclockingGaming HotkeyGaming Device Port
Game Boost 1 second overclockingGaming HotkeyGaming Device Port
X-Boost your Storage Performance
When enabled, X-Boost auto-detects and optimizes your SSDs to keep your system fast and maximize storage performance, making sure you reach the battlefield even quicker or saving you a lot of time when transferring data.
X-boost performance
Immerse yourself into Virtual Worlds
Want the best of the best VR experience without any compromise? Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid, smooth and realistic experience in which content truly comes alive.
VR ReadyHTC Vive
HTC Vive
Amplify your Game with Audio Boost
Like a dedicated sound card Audio Boost offers a HD audio processor, dedicated amplifier and high quality audio capacitors, all physically isolated from the rest of the motherboard circuitry to ensure the purest audio signal to locate enemies with pin-point accuracy.
Isolated Audio with LED LineChemi-Con Audio capacitors
Isolated audio design with Isolated Audio with LED LineChemi-con Audio Capacitors
Audio Boost logo
Audio Boost Ohm chart
Dominate the Game with the Lowest Latency
Get ready to crush your enemies on the battlefield with MSI GAMING LAN. Featuring the highest quality components tuned to deliver the best online gaming experience without lag.
Optimize Killer Gaming LAN
Unmatched Memory Performance
MSI motherboards are crammed with features to fuel your gaming rig’s memory with more speed, higher overclockability and increased stability.
Memory Signal PurityMSIMSI captionOthersMSI caption
DDR4 Boost performance
Best compatibility
Optimized traces and a fully isolated memory circuitry ensures perfect stability and performance, so you never have to worry about your system crashing during games.
Best compatibility chart
Maximize your USB Device performance
Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of options to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds!
Up to 20% faster with XBoost
XBoost performance
Built on everlasting quality
Only the finest quality components and latest innovations are used. Rigorous quality testing under the most extreme conditions ensures a super reliable, high performance motherboard.
No strengthening others
Others
No strengthening
Strengthening-steel-armor Steel Armor
MSI Steel armor
Reinforced, heavy soldered connections
Steel Armor slot
Reinforced Steel PCIe Slot, Protects Against EMI
MSI B350M GAMING PRO - motherboard - micro ATX - Socket AM4 - AMD B350 FCH
Motherboard - micro ATX
Chipset Type
AMD B350 FCH
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4 unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI B350M GAMING PRO A...
