MSI GeForce GT 710 1GB DDR3 Dual-DVI-D HDMI Graphics Card
£35.83
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Lower temperature and higher efficiency
  • Extreme low ESR
  • Large heat sink covers the area of GPU and memory
  • Providing the best environment for gaming and multimedia
  • Low profile design saves more spaces
  • User can build slim or smaller system easier
  • Graphics Processor Manufacturer: NVIDIA
  • Graphics Processor: NVIDIA GeForce GT 710, NVIDIA GeForce GT 710, NVIDIA GeForce GT 710
  • Interface: PCI Express 2.0 x16
  • Memory Size: 1GB
  • Stock Status: In Stock
Product codes
Core/Memory
• 954 MHz Core
• 1024MB DDR3 1600 MHz
Video Output Function
• Dual-link DVI-D x 1
• HDMI x 1 (Version 1.4a)
• D-Sub x 1
All Solid Capacitors
10 years ultra-long lifetime (under full load).
Lower temperature and higher efficiency.
Extreme low ESR.
Noise Free
Large heat sink covers the area of GPU and memory.
Providing the best environment for gaming and multimedia.
Low Profile Design
Low profile design saves more spaces.
User can build slim or smaller system easier.
Afterburner Overclocking Utility
Support in-game video recording.
Support wireless control by android/iOS handheld devices.
Support built-in DX12 effect test.
Product Description MSI GT 710 1GD3H LP - graphics card - GF GT 710 - 1 GB
Device Type Graphics card - low profile
Bus Type PCI Express 2.0 x16
Graphics Engine NVIDIA GeForce GT 710
Memory 1 GB DDR3
Core Clock 954 MHz
Effective Memory Clock 1.6 GHz
RAMDAC 400 MHz
Memory Interface 64-bit
Max Resolution 4096 x 2160
Max Monitors Supported 2
Interfaces DVI-D (dual link) , HDMI , VGA
API Supported DirectX 12, OpenGL 4.5
Dimensions (WxDxH) 1.9 cm x 14.6 cm x 6.9 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI GeForce GT 710 1GB...
£35.83
