Core/Memory
• 954 MHz Core
• 2048MB DDR3 1600 MHz
Video Output Function
• Dual-link DVI-D x 1
• HDMI x 1 (Version 1.4a)
• D-Sub x 1
All Solid Capacitors
10 years ultra-long lifetime (under full load).
Lower temperature and higher efficiency.
Extreme low ESR.
Noise Free
Large heat sink covers the area of GPU and memory.
Providing the best environment for gaming and multimedia.
Low Profile Design
Low profile design saves more spaces.
User can build slim or smaller system easier.
Afterburner Overclocking Utility
Support in-game video recording.
Support wireless control by android/iOS handheld devices.
Support built-in DX12 effect test.
Product Description | MSI GT 710 2GD3H LP - graphics card - GF GT 710 - 2 GB | Device Type | Graphics card - low profile | Bus Type | PCI Express 2.0 x16 | Graphics Engine | NVIDIA GeForce GT 710 | Memory | 2 GB DDR3 | Core Clock | 954 MHz | Effective Memory Clock | 1.6 GHz | RAMDAC | 400 MHz | Memory Interface | 64-bit | Max Resolution | 4096 x 2160 | Max Monitors Supported | 2 | Interfaces | DVI-D (dual link) , HDMI , VGA | API Supported | DirectX 12, OpenGL 4.5 | Dimensions (WxDxH) | 1.9 cm x 14.6 cm x 6.9 cm |
General | |
RAMDAC | 400 MHz |
Max Resolution | 4096 x 2160 at 24 Hz |
Features | MSI Solid Capacitor, fanless heatsink, MSI Afterburner, HDCP |
Memory | |
Size | 2 GB |
Technology | DDR3 SDRAM |
Effective Clock Speed | 1.6 GHz |
Bus Width | 64-bit |
System Requirements | |
Required Power Supply | 300 W |
Miscellaneous | |
Power Consumption Operational | 19 Watt |
Software Included | Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Afterburner, display drivers, Norton Internet Security (60 days trial) |
Width | 1.9 cm |
Depth | 14.6 cm |
Height | 6.9 cm |
Weight | 178 g |
