MSI GeForce GTX 1050 GAMING X 2GB GDDR5 PCIe3.0 Graphics Card
£135.54
Delivery:
Standard: 1-3 working days
Key features
  • TORX 2.0 fan
  • Airflow control technology
  • The future of gaming
  • Graphics Processor Manufacturer: NVIDIA
  • Graphics Processor: NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050
  • Interface: PCI Express 3.0 x16
  • Memory Size: 2GB, 2GB
  • Digital Output: DisplayPort, Dual DVI, High-Definition Multimedia Interface (HDMI)
Product codes
TWIN FROZR VI
- The Ultimate Thermal Design
The new TWIN FROZR VI Thermal Design raises the bar of Graphics Card air cooling. It's 40% more silent compared to the award winning TWIN FROZR V. Details make all the difference.
Twin Frozr logo
GTX 1050 GAMING X 8G exploded view
  • Dynamic LED
  • Military Class Components
  • Tailored PCB Design
  • Heatsink
  • TORX 2.0 Fan
  • Zero Frozr
GAMING X logo
TWIN FROZR VI: Cool, Silent & Stable Performance
Perfectly balanced with excellent cooling for stable gaming performance while staying incredibly silent during intense gaming.
Cool
Cooling graph
Max. temp (10 mins of FireStrike)
Silent
Noise graph
Noise under load
Stable performance
Performance graph Stable performance Unstable performance
Torx Fan 2.0 logo
TORX 2.0 FAN - Teamwork for greater strength
The exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool.
TORX 2.0 Fan design generates 22% more air fan pressure for supremely silent performance in the heat of battle.
 Dispersion fan airflow
Dispersion fan blade
Traditional fan blade
ZERO FROZR - Stay Undetected
First introduced in 2008 by MSI, Zero Frozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Zero Frozr
> 60°C: Fans spinning
During intense gaming or benchmarking
60 Fans stop
Completely silent during idle, multimedia or light gaming
Catch the vibe with cool LED effects
Each LED can be controlled individually by choosing any of the animation effects available in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
Led effects MSI Gaming App
Software
Supports
Nvidia G-Sync logo
Product Description MSI GTX 1050 GAMING X 2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 1050
Memory 2 GB GDDR5
Core Clock 1442 MHz
Boost Clock 1556 MHz
Effective Memory Clock 7.108 GHz
Memory Interface 128-bit
Max Resolution 2560 x 1600
Max Monitors Supported 3
Interfaces DVI-D (dual link) , DisplayPort , HDMI
API Supported DirectX 12, OpenGL 4.5
Dimensions (WxDxH) 3.9 cm x 22.9 cm x 13.1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI GeForce GTX 1050 G...
£135.54
