MSI GeForce GTX 1070 GAMING X 8G 8GB GDDR5 Graphics Card
Key features
  • TORX 2.0 fan technology
  • Catch the vibe with cool LED effects
  • Airflow Control technology
  • Smooth heat pipes
  • Solid baseplate
  • Multi GPU technologies
Product codes
GeForce® GTX 1070 GAMING X 8G
Core/Memory
Boost Clock / Base Clock:
1797 MHz / 1607 MHz (OC Mode)
1771 MHz / 1582 MHz (Gaming Mode)
1683 MHz / 1506 MHz (Silent Mode)
8192 MB GDDR5 / 8108 MHz Memory (OC Mode)
Video Output Function
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
TORX 2.0 FAN
Teamwork for greater strength
Just like in games, the exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool.
TORX 2.0 Fan design generates 22% more air pressure for supremely silent performance in the heat of battle.
Zero Frozr-Stay undetected
First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Catch the Vibe with Cool LED Effects
Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
HEATSINK
Lurking under the cover of the GAMING graphics card is an engineering masterpiece designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool & quiet gaming experience.
Airflow Control Technology
Using advanced aerodynamics, Airflow Control Technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
Multi GPU
Gaming enthusiasts are always looking for more performance to get the ultimate experience. Using multiple graphics cards in SLI or Crossfire is a great way to find out just how good it gets. MSI GAMING graphics cards fully support multi GPU technologies.
PREPARE FOR VR with MSI
To experience and enjoy the impressive world of Virtual Reality, high-performance hardware is required. MSI, world leading brand in high-end gaming and eSports, provides the right advice to make sure your system is VR Ready. Integrating the very best of cutting edge technologies in recommended MSI VR gaming hardware for smooth performance. Together with our VR partners, MSI brings gamers an extremely realistic VR experience where games come alive.
Product Description MSI GTX 1070 GAMING X 8G - graphics card - GF GTX 1070 - 8 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 1070
Memory 8 GB GDDR5
Core Clock 1607 MHz
Boost Clock 1797 MHz
Effective Memory Clock 8.108 GHz
Memory Interface 256-bit
Max Resolution 7680 x 4320
Max Monitors Supported 4
Interfaces DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported DirectX 12, OpenGL 4.5
Dimensions (WxDxH) 4.2 cm x 27.9 cm x 14 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI GeForce GTX 1070 G...
