MSI H110M PRO-VH Intel S1151 DDR4 USB3.0 PCIe SATA3 uATX
Key features
  • Supports DDR4-2133 memory
  • DDR4 Boost - give your DDR4 memory a performance boost
  • USB 3.1 Gen1 + SATA 6Gb/s
  • VGA Armor - reinforced Armor slot
  • Click BIOS - secure and reliable UEFI BIOS solution
  • Audio Boost - reward your ears with studio grade sound quality
  • Military Class 4 - top quality & stability
  • Guard-Pro - improved protection and power efficiency
  • EZ Debug LED - easiest way to troubleshoot
  • Overvoltage protection - prevent unforeseen damage
  • 4K UHD support - ultra-high definition visual experience
  • Intel SBB support - improves productivity, management and security
Product codes
The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
MSI H110M PRO-VH - motherboard - micro ATX - LGA1151 Socket - H110
Motherboard - micro ATX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600
USB / FireWire Ports
USB 3.1 Gen 1 2 x USB 3.1 Gen 1 + 4 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI H110M PRO-VH Intel...
