MSI H270 TOMAHAWK ARCTIC LGA1151 Intel H270 DDR4 ATX
Key features
  • Personalize your gaming rig
  • Stay cool while gaming
  • Your in-game advantage
  • Be the first on the battlefield
  • Immerse yourself into virtual worlds
  • Sound that pulls you into the game
  • Dominate the game with the lowest latency
  • Unmatched memory performance
  • Designed for limitless tuning
  • Maximize your USB device performance
  • Built on everlasting quality
  • A gamer' BIOS
Product codes
Personalize Your Gaming Rig
Connect external RGB strips and sync other RGB capable gear to set up your own colour scheme using only 1 application: Mystic Light Sync. Select any of the colours from the palette using your smartphone or the MSI Gaming App to match your system style. Feel like using a different colour? Completely change the look of your system in 1 second!
Fully Controllable Fan Headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
Your In-Game Advantage
Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills.
X-Boost Your Storage Performance
When enabled, X-Boost auto-detects and optimizes your SSDs to keep your system fast and maximize storage performance, making sure you reach the battlefield even quicker or saving you a lot of time when transferring data.
Intel Optane™ Ready
This new technological marvel brings game-changing performance to memory and storage devices. Allow Optane™ caching to boost your storage devices for an even faster gaming system!
Immerse Yourself into Virtual Worlds
Want the best of the best VR experience without any compromise? Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid, smooth and realistic experience in which content truly comes alive.
Raise Your Sound Quality with Audio Boost
Built on years of experience in building motherboards dedicated to providing true Hi-Fi sound. Audio Boost has developed into a high quality audio unit, offering a clear improvement in sound quality.
  • Isolated Audio with LED Line.
  • Chemi-Con Audio capacitors.
Product Description MSI H270 TOMAHAWK ARCTIC - motherboard - ATX - LGA1151 Socket - H270
Product Type Motherboard - ATX
Chipset Type Intel H270
Processor Socket 1 x LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4
Storage Ports 6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI H270 TOMAHAWK ARCT...
