We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | MSI Optix AG321CQR - LED monitor - curved - 31.5" | Device Type | LED-backlit LCD monitor - 31.5" | Energy Class | Class G | Energy Consumption per Year | 68 kWh | Power Consumption (On mode) | 40 W | Curved Screen | Yes | Adaptive-Sync Technology | VESA Adaptive-Sync | Features | 5-way joystick, USB 3.2 Gen 1 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | UWQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz) | Pixel Pitch | 0.2724 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey), 1 ms (MPRT), 21 ms (tr - tf) | Gaming | Yes | Colour Support | 1.07 billion colours | Colour Gamut | 105.84% Adobe RGB (CIE 1976), 107.83% NTSC (CIE 1976), 123.62% sRGB (CIE 1976), 128.68% sRGB (CIE 1931), 91.14% NTSC (CIE 1931), 94.86% DCI-P3 (CIE 1931), 95.39% Adobe RGB (CIE 1931), 98.56% DCI-P3 (CIE 1976) | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 71 cm x 28.6 cm x 46.5 cm | Weight | 6.59 kg | Compliant Standards | BSMI, CB, PSE Mark, MEPS, LVD, RCM, DisplayPort 1.2, CE/EMC, HDCP 2.2, CIE1931, CIE1976 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 31.5" |
Curved Screen | Yes (1500R) |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | VA |
Vertical Refresh Rate | 30 - 165 Hz |
Horizontal Refresh Rate | 90.9 - 242 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Adaptive-Sync technology, frameless bezel design, HDR Ready technology, MSI Mystic Light, Gaming Mode, 10-bit(8-bit + FRC) Colour Depth |
Colour | Black |
Dimensions (WxDxH) | 71 cm x 28.6 cm x 46.5 cm - with stand |
Weight | 6.59 kg |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | 2 x HDMI (HDCP 2.2) , DisplayPort 1.2 (HDCP 2.2) , Headphones , USB 3.2 Gen 1 (Type A) |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 60 |
Rotation Angle | 10 |
Height Adjustment | 90 mm |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x USB-A to USB-B cable , 1 x power cable , 1 x power adapter |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 40 kWh/1000h |
Power Consumption HDR (On mode) | 51 kWh/1000h |
Power Consumption (Typical) | 46 Watt |
Power Consumption Stand by | 0.33 Watt |
Power Consumption (Off Mode) | 0.28 Watt |
Software / System Requirements | |
Included Software | MSI Gaming OSD App |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 71 cm - depth: 10.3 cm - height: 41.8 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 94.3 cm |
Shipping Depth | 17.1 cm |
Shipping Height | 53.9 cm |
Shipping Weight | 8.98 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
