MSI Optix AG321CR 31.5" Curved Gaming Monitor
£269.00
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Curved gaming display (1500R) - great gameplay immersion
  • 165Hz refresh rate - real smooth gaming
  • 1ms response time - eliminate screen tearing and choppy frame rates
  • Night Vision - see every detail clearly in the dark, helping you find and attack enemies before they notice
  • AMD FreeSync Premium technology - tear-free, stutter-free, fluid gaming
  • Anti-Flicker and Less Blue Light - game even longer and prevent eye strain and fatigue
  • Diagonal Size: 31.5in
Product codes
Visualize your victory with the MSI AG321CR Curved Gaming monitor. Equipped with a 1920 x 1080 resolution, 165Hz refresh rate, 1ms response time panel, AG321CR will give you the competitive edge you need to take down your opponents. Built with AMD FreeSync Premium technology, AG321CR can match the display's refresh rate with your GPU for ultra-smooth gameplay. Make sure you can hit your mark with all the latest technologies built in the MSI Curved Gaming monitor for competitive play.
Product Description MSI Optix AG321CR - LED monitor - curved - Full HD (1080p) - 31.5"
Device Type LED-backlit LCD monitor - 31.5"
Energy Class Class F
Energy Consumption per Year 68 kWh
Power Consumption (On mode) 29 W
Curved Screen Yes
Adaptive-Sync Technology AMD FreeSync Premium
Features 5-way joystick
Panel Type VA
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch 0.36375 mm
Brightness 250 cd/m²
Contrast Ratio 4000:1 / 100000000:1 (dynamic)
Response Time 4 ms (grey-to-grey), 14 ms (tr - tf), 1 ms (MPRT)
Gaming Yes
Colour Support 16.7 million colours (8-bit)
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Voltage AC 120/230 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) - with stand 71 cm x 28.6 cm x 46.5 cm
Weight 6.59 kg
Compliant Standards BSMI, CB, EMC, FCC, MEPS, LVD, RCM, DisplayPort 1.2, HDCP 2.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£269.00
