We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Visualize victory with the MSI Optix G241V E2 esports gaming monitor. Equipped with a 1920x1080, 75Hz refresh rate, 1ms response time panel, Optix G241V E2 will give you the competitive edge you need. Built with FreeSync technology, Optix G241V E2 can match the display's refresh rate with your GPU for ultra-smooth gameplay. Reach the peak of immersion with the latest technologies built into MSI gaming monitors.
Product Description | MSI Optix G241V E2 - LED monitor - Full HD (1080p) - 23.8" | Device Type | LED-backlit LCD monitor - 23.8" | Energy Class | Class E | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 18 W | Adaptive-Sync Technology | AMD FreeSync | Features | 5-way joystick | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey), 1 ms (MPRT) | Gaming | Yes | Colour Support | 16.7 million colours | Colour Gamut | 102.4% Rec 709 (CIE 1976), 102.4% sRGB (CIE 1976), 104.93% NTSC (CIE 1931), 104.93% sRGB (CIE 1931), 77.35% DCI-P3 (CIE 1931), 77.35% Rec 709 (CIE 1931), 77.77% Adobe RGB (CIE 1931), 81.6% DCI-P3 (CIE 1976), 87.8% Adobe RGB (CIE 1976), 89.3% NTSC (CIE 1976) | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50 - 60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.03 cm x 21.96 cm x 42.26 cm | Weight | 3.3 kg | Compliant Standards | CB, DisplayPort 1.2a, CIE1976 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Panel Type | IPS |
Vertical Refresh Rate | 47 - 77 Hz |
Horizontal Refresh Rate | 30 - 100 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Frameless, game mode, blue light reduction, Wide Colour Gamut, MSI Anti-Flicker, night vision mode, 8-bit(6-bit + FRC) Colour Depth |
Colour | Black |
Dimensions (WxDxH) | 54.03 cm x 21.96 cm x 42.26 cm - with stand |
Weight | 3.3 kg |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | HDMI , DisplayPort 1.2a , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 18 kWh/1000h |
Power Consumption (Typical) | 25 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.03 cm - depth: 21.96 cm - height: 42.26 cm - weight: 3.3 kg , Without stand - width: 54.03 cm - depth: 6.55 cm - height: 32.82 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 60.6 cm |
Shipping Depth | 17.2 cm |
Shipping Height | 40.9 cm |
Shipping Weight | 5 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
