We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Optix monitors use a curved display panel that has a curvature rate of 1500R, which is the most comfortable and suitable for a wide range of applications from general computing to gaming. Curved panels also help with gameplay immersion, making you feel more connected to the entire experience.
Product Description | MSI Optix G27CQ4 - LED monitor - curved - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class G | Energy Consumption per Year | 57 kWh | Power Consumption (On mode) | 32.2 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Features | 5-way joystick | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz) | Pixel Pitch | 0.2331 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 / 100000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey), 1 ms (MPRT) | Gaming | Yes | Colour Support | 16.7 million colours (8-bit) | Colour Gamut | 115% sRGB, 92% DCI-P3 | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50 - 60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 61.15 cm x 22.54 cm x 45.79 cm | Weight | 5.4 kg | Compliant Standards | VCCI, BSMI, CB, PSE Mark, MEPS, KC, RCM, MSIP, DisplayPort 1.2a, CE/EMC, K-MEPS, CIE1976 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Curved Screen | Yes (1500R) |
Panel Type | VA |
Vertical Refresh Rate | 48 - 165 Hz |
Horizontal Refresh Rate | 70.56 - 243.37 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Blue light reduction, MSI Anti-Flicker, frameless bezel design, night vision mode |
Colour | Black |
Dimensions (WxDxH) | 61.15 cm x 22.54 cm x 45.79 cm - with stand |
Weight | 5.4 kg |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | DisplayPort , 2 x HDMI , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V (50 - 60 Hz) |
Power Consumption SDR (On mode) | 32.2 kWh/1000h |
Power Consumption (Typical) | 40 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.15 cm - depth: 22.54 cm - height: 45.79 cm - weight: 5.4 kg , Without stand - width: 61.15 cm - depth: 7.59 cm - height: 37.28 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 75.6 cm |
Shipping Depth | 16.8 cm |
Shipping Height | 47.3 cm |
Shipping Weight | 9 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
