MSI Optix MAG274QRF-QD eSports Gaming Monitor
£499.00
Delivery:
Standard: 1-3 working days
Key features
  • Rapid IPS - provides 1ms GTG fast response time, optimizes screen colors and brightness
  • Quantum Dot - provides accurate color imagery and support a cinema-standard DCI-P3 color gamut
  • WQHD high resolution - games will look even better, displaying more details
  • 165Hz refresh rate - respond faster with smoother frames
  • 1ms GTG response time - eliminate screen tearing and choppy frame rates
  • NVIDIA G-Sync compatible - prevent screen tearing or stuttering, producing ultra-smooth lag-free gameplay
  • Diagonal Size: 27in
Product codes
Visualize your victory with MSI Optix MAG274QRF-QD eSports gaming monitor. Equipped with a 165Hz refresh rate, 1ms GTG response time panel, Optix MAG274QRF-QD will give you the competitive edge you need to take down your opponents. The WQHD (2560x1440) high resolution and the Quantum Dot technology will let you experience the mesmerizing images. Enjoy extremely smooth, tear-free gameplay with built-in NVIDIA G-Sync compatible technology when paired with a compatible NVIDIA graphics card.
Product Description MSI Optix MAG274QRF-QD - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class B
Energy Consumption per Year 54 kWh
Power Consumption (On mode) 37 W
Adaptive-Sync Technology NVIDIA G-SYNC Compatible
Features 5-way joystick, USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz, USB-C: 165 Hz)
Pixel Pitch 0.2331 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 1 ms (MPRT)
Gaming Yes
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Voltage AC 120/230 V (50 - 60 Hz)
Colour Black
Dimensions (WxDxH) 61.49 cm x 20.67 cm x 53.27 cm
Weight 6.05 kg
Compliant Standards DisplayPort 1.4
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£499.00
