We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Visualize your victory with MSI Optix MAG274QRX eSports gaming monitor. Equipped with a 2560 x 1440, 240 Hz refresh rate, 1 ms GTG response time panel, Optix MAG274QRX will give you the competitive edge you need to take down your opponents. Enjoy extremely smooth, tear-free gameplay with built-in NVIDIA G-Sync compatible technology. Make sure you can hit your mark with all the latest technologies built-in the MSI esports gaming monitors for competitive play.
Product Description | MSI Optix MAG274QRX - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class F | Adaptive-Sync Technology | NVIDIA G-SYNC Compatible | Features | 5-way joystick, USB 2.0 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | WQHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz, USB-C: 165 Hz) | Pixel Pitch | 0.2331 mm | Brightness | 300 cd/m² | Contrast Ratio | 100000000:1 (dynamic) | Response Time | 1 ms (grey-to-grey) | Gaming | Yes | Colour Support | 1.07 billion colours | Colour Gamut | 124% sRGB, 95% DCI-P3 | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) | 61.49 cm x 20.67 cm x 53.27 cm | Weight | 6.05 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 27" |
Built-in Devices | USB 2.0 hub |
Panel Type | IPS |
Vertical Refresh Rate | 30 - 165 Hz |
Horizontal Refresh Rate | 90.9 - 242.4 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Wide Colour Gamut, frameless bezel design, night vision mode, MSI Mystic Light, 8-bit + FRC Colour Depth |
Weight | 6.05 kg |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | 2 x HDMI , DisplayPort , USB-C , USB upstream (Type B) , 2 x USB downstream (Type A) , Headphones |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 150 |
Rotation Angle | 180 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 26 kWh/1000h |
Power Consumption HDR (On mode) | 41 kWh/1000h |
Power Consumption (Typical) | 32 Watt |
Dimensions & Weight (Shipping) | |
Shipping Width | 73 cm |
Shipping Depth | 22 cm |
Shipping Height | 49 cm |
Shipping Weight | 8.7 kg |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
