MSI Optix MEG381CQR Plus Gaming Monitor
£1,507.34
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 38in
Product codes
There's gaming, and there's truly premium gaming. The MSI Optix MEG381CQR QHD+ monitor delivers the latter - in a big way. A gorgeous curved 21:9 ultra-wide IPS panel brings brilliant color accuracy and wide viewing angles to you. The amount of screen real estate that this 38-inch 3840x1600 resolution monitor offers is truly mind-boggling. A curve brings even the edges of that massive screen within your peripheral view - granting you an immersive experience like you've never experienced without compromising usability.
Talking about immersion, the Optix MEG381CQR Plus comes with official VESA DisplayHDR 600 certification and NVIDIA's G-Sync Ultimate badge. True HDR gaming will give you a brand-new perspective on the beauty of a game world. With deeper blacks and better brightness levels, you can explore vast worlds exactly how game designers envisioned them.
Visual quality should never come at the cost of fluidity. The ultra-wide MEG381CQR Plus doesn't compromise on refresh rate one bit. It comes with a blazing-fast 175Hz refresh rate to ensure that not even the most hardcore competitive gamer will have to compromise on smoothness to gain quality and screen real estate. You can have it all.
The MEG381CQR Plus also features GameSense - a unique way to receive game alerts with ambient lighting. GameSense supports the hottest online competitive games and delivers events like low health, healing, incoming damage, etc., using the RGB LED lighting on the monitor. Not only does it enhance your immersion, but it also makes you more aware of important events like taking damage. Of course, MSI Mystic Light support will allow you to tie in your monitor's lighting with the rest of your system.
Propping your webcam atop a razor-thin bezel on your monitor is just triggering for many. The convenient camera cradle on the MEG381CQR Plus allows you to mount your webcam without intruding into your screen. A built-in mouse bungee on the monitor successfully manages your mouse wire without restricting its movement in the least.
Product Description MSI Optix MEG381CQR Plus - LED monitor - curved - 37.5"
Device Type LED-backlit LCD monitor - 37.5"
Energy Class Class G
Curved Screen Yes
Adaptive-Sync Technology NVIDIA G-SYNC ULTIMATE
Features 5-way joystick, USB 3.2 Gen 1 hub
Panel Type IPS
Aspect Ratio 21:9
Native Resolution UWQHD+ 3840 x 1600 (DisplayPort: 175 Hz, HDMI: 85 Hz)
Pixel Pitch 0.22908 mm
Brightness 600 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 1 ms
Colour Support 1.07 billion colours
Colour Gamut 128.7% sRGB, 96.2% DCI-P3
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare
Voltage AC 100-240 V (50/60 Hz)
Colour Black
Dimensions (WxDxH) 89.65 cm x 32.58 cm x 46.64 cm
Weight 10.7 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£1,507.34
