MSI Optix MPG321UR-QD eSports Gaming Monitor
£968.62
Delivery:
Notify me
  • Diagonal Size: 32in
Product codes
If only you could combine the crisp details of a 4K gaming experience with the fluidity of a high refresh rate monitor. Well, MSI's Optix MPG321UR-QD 4K 144Hz Monitor does precisely that. And does it well.
The amount of screen real estate that a 4K monitor brings to the table is unreal for many, especially on a large 32-inch monitor like the MPG321UR-QD. It features a top-notch IPS panel that delivers the much-needed combination of accurate colors, wide viewing angles, and exceptional brightness levels.
With the launch of this 4K 144Hz monitor that features an excellent response time of just 1ms (GTG), competitive gamers can now finally think of making the switch to the much-coveted 4K resolution. It gives you much more information while keeping your gameplay as fluid as you're used to as long as your Gaming PC can deliver enough performance.
While a regular KVM gives your peripherals the ability to control multiple systems, MSI takes it a step further with the inclusion of KVM 3.0 on this 4K 144Hz gaming monitor. In addition to just managing several devices with a single keyboard, mouse, and game controller, you can now also transfer files between them!
Console users can rejoice, too, as the Optix MPG321UR-QD also features the latest HDMI 2.1 port. It allows you to enjoy the full, unbridled 4K 120Hz experience even when gaming on a new-generation console.
Product Description MSI Optix MPG321UR-QD - LED monitor - 4K - 32" - HDR
Device Type LED-backlit LCD monitor - 32"
Energy Class Class G
Adaptive-Sync Technology NVIDIA G-SYNC Compatible
Features 5-way joystick, USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 144 Hz
Pixel Pitch 0.1845 mm
Brightness 600 cd/m²
Contrast Ratio 1000:1
HDR Capable DisplayHDR 600
Response Time 1 ms (MPRT)
Gaming Yes
Colour Support 1.07 billion colours
Colour Gamut 99% Adobe RGB, 97% DCI-P3 (CIE 1976), 143% sRGB (CIE 1976)
Input Connectors 2xHDMI, DisplayPort, USB-C
Display Position Adjustments Height, swivel, tilt
Screen Coating Anti-glare
Voltage AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) 72.71 cm x 25.18 cm x 48.22 cm
Weight 10.1 kg
Compliant Standards DisplayPort 1.4a
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£968.62
Notify me
