We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | MSI Optix MPG341QR - LED monitor - 34" - HDR | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Adaptive-Sync Technology | NVIDIA G-SYNC Compatible | Features | 5-way joystick, KVM Switch, USB 2.0 hub | Panel Type | IPS | Aspect Ratio | 21:9 | Native Resolution | UWQHD 3440 x 1440 (DisplayPort: 144 Hz, HDMI: 100 Hz, USB-C: 144 Hz) | Pixel Pitch | 0.2325 mm | Brightness | 550 cd/m² | Contrast Ratio | 1000:1 / 100000000:1 (dynamic) | HDR Capable | HDR400 | Response Time | 1 ms | Gaming | Yes | Colour Support | 1.07 billion colours | Colour Gamut | 88.2% Adobe RGB (CIE 1976), 91.5% DCI-P3 (CIE 1976), 122.5% sRGB (CIE 1976) | Input Connectors | 2xHDMI, DisplayPort, USB-C | Display Position Adjustments | Height, swivel, tilt | Screen Coating | Anti-glare | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) - with stand | 81.74 cm x 25.226 cm x 42.27 cm | Weight | 9.38 kg | Compliant Standards | DisplayPort 1.4, CIE1976 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Built-in Devices | KVM Switch, USB 2.0 hub |
Panel Type | IPS |
HDR Format | HDR400 |
Vertical Refresh Rate | 48 - 144 Hz |
Horizontal Refresh Rate | 72 - 216 kHz |
Gaming | Yes |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture by picture, Crosshair Display, Wide Colour Gamut, MSI Anti-Flicker, frameless bezel design, Picture-in-Picture, Low Blue Light technology, night vision mode, MSI Mystic Light, 10-bit(8-bit + FRC) Colour Depth, Rapid Boost, mouse bungee |
Dimensions (WxDxH) | 81.74 cm x 25.226 cm x 42.27 cm - with stand |
Weight | 9.38 kg |
Input | |
Type | 5-way joystick |
Connectivity | |
Interfaces | DisplayPort 1.4 , 2 x HDMI , USB-C/DisplayPort Alt Mode , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream , Headphones |
Mechanical | |
Tilt Angle | -5/20 |
Swivel Angle | 60 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 39.9 kWh/1000h |
Power Consumption HDR (On mode) | 75 kWh/1000h |
Power Consumption (Typical) | 40 Watt |
Software / System Requirements | |
Included Software | MSI Gaming OSD App |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 81.74 cm - depth: 25.226 cm - height: 42.27 cm - weight: 9.38 kg , Without stand - width: 81.74 cm - depth: 6.524 cm - height: 37.42 cm |
Dimensions & Weight (Shipping) | |
Shipping Width | 84.7 cm |
Shipping Depth | 17.1 cm |
Shipping Height | 64 cm |
Shipping Weight | 13.8 kg |
