MSI X299 GAMING M7 ACK Intel X299 S2066 DDR4 U.2 USB3.1 ATX
£374.16
Delivery:
Key features
  • Stay cool while gaming
  • Be the first on the battlefield
  • Unmatched memory performance
  • Maximize your USB device performance
  • Processor Socket: LGA2066 Socket
  • Chipset: Intel X299 Express
  • Graphics: None
  • Form Factor: ATX
  • Memory Support: DDR4 SDRAM
Product codes
X299 GAMING M7 ACK
Intel X299 Motherboard
• Supports New Intel® Core™ X-series Processor Family for LGA 2066 socket
• Support Quad Channel DDR4-4133(OC)+, Dual Channel DDR4-4500(OC)+
• M.2 SHIELD FROZR: Strengthened built-in M.2 thermal solution. Keeps M.2 safer and faster.
• 3D Printing Support: Modify and customize your system with the use of special 3D screws.
• Mystic Light: Personalize your PC with 16.8 million colors / 17 effects controlled in one click with the Mystic Light APP or a mobile device.
• Audio Boost 4 PRO: Isolated audio with 2x audio processors & Nahimic 2+ for the most immersive gaming experience.
• Killer DoubleShot PRO: Delivers industry-leading speed using Killer’s Lag and Latency Reduction™ Technology via both Killer Ethernet and WIFI
• Designed for Extreme Performance: TURBO SOCKET with GAME BOOST, DIGITALL POWER Design
• Lightning Fast Game experience: TWIN TURBO M.2 and Intel Optane Memory Ready, Turbo U.2, LIGHTNING USB 3.1 GEN2
• DDR4 Boost with Steel Armor: Fully isolated, shielded and optimized DDR4 PCB design to give your DDR4 memory a performance boost.
• MULTI-GPU: With STEEL ARMOR PCI-E slots. Supports 3-Way NVIDIA SLI™ & 3-Way AMD Crossfire™
• SYSTEM SAVER: 3 easy to use options to successfully boot your system again.
Product Description MSI X299 GAMING M7 ACK - motherboard - ATX - LGA2066 Socket - X299
Product Type Motherboard - ATX
Chipset Type Intel X299 Express
Processor Socket 1 x LGA2066 Socket
Compatible Processors Core X
Max RAM Size 128 GB
RAM Supported 8 DIMM slots - DDR4
Storage Ports 8 x SATA-600 (RAID), 2 x M.2, 1 x U.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 3 x USB 2.0 + (1 x USB-C Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI X299 GAMING M7 ACK...
£374.16
