MSI Z270 SLI PLUS LGA1151 Intel Z270 DDR4 ATX
Key features
  • Personalize your gaming
  • Stay cool
  • Professional sound quality
  • Stable, secure & fast networking
Product codes
Fully Controllable Fan Headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
Multi GPU Support
Professionals and enthusiasts strive for the best performance to make their systems faster. MSI motherboards fully support multi GPU technologies. Optimal PCI slot placement allows for the best fit and usage conditions to ensure the best thermal conditions.
Extreme Storage Performance: 2x Turbo M.2
Enjoy a blazing fast system boot up and insanely quick loading of applications and data. Delivering speeds up to 32Gb/s per device using Gen3 x4, Turbo M.2 is over 5 times faster than a regular SATA III connection! You can even mix up devices and set up RAID easily using M.2 Genie, for even better performance.
X-Boost Your Storage Performance
When enabled, X-Boost auto-detects and optimizes your SSDs to keep your system fast and maximize storage performance, making sure you reach the battlefield even quicker or saving you a lot of time when transferring data.
Intel Optane™ Ready
This new technological marvel brings game-changing performance to memory and storage devices. Allow Optane™ caching to boost your storage devices for an even faster gaming system!
Product Description MSI Z270 SLI PLUS - motherboard - ATX - LGA1151 Socket - Z270
Product Type Motherboard - ATX
Chipset Type Intel Z270 Express
Processor Socket 1 x LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports 6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
MSI Z270 SLI PLUS LGA1...
