Nanoleaf Light Panels Starter Kit (9xPanels + Control)
Key features
  • Color-changing light
  • Double-sided mounting pads for no-holes, no-hassles installation of light panels
  • Express your creativity with panels that snap together in any shape you want
  • Easily schedule your scenes to seamlessly integrate with your life
Product codes
Illuminate Your Life Your Way.
A Brand New Lighting Experience.
Nanoleaf Light Panels are a smart lighting product unlike anything you’ve seen before. Wake up to the sunrise, improve your mood with stunning colors, and automate your lighting throughout the day.
How the Light Panels Work
Piece the triangular panels together into whatever shape your heart desires. Easily mounted onto any flat surface using mounting tape.
Fully customize your lighting inside the App, create scenes, set schedules, or download/share your scenes with the user community.
Activate scenes using your voice via Siri, Amazon Alexa, or Google Assistant. Or use the toggle button on the physical controller.
Guided Content Discovery
Create, share, preview, and download at the tap of a finger.
There’s an entire community of creators and music enthusiasts dreaming up new Scenes. Be one of them and share your Light Panels and Rhythm Scenes, or preview and download Scenes shared by others.
Nanoleaf Aurora - wireless lighting set - LED
Wireless lighting set - triangle
Light Bulb Type
LED
Packaged Quantity
9 (specifications are for single item)
Dimmer
Wattage
2 W
Colour of Illumination
RGBW light
Colour Temperature
3000 K
Luminous Power
100 lumens
AC 100 - 240 V
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nanoleaf Light Panels...
