Nest Cam Indoor Security Camera
FREE DELIVERY
£129.00
Select:
  • Single
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Records everything
  • Alerts you when something happens
  • Lets you talk and listen
  • Type: Home security system, Indoor Camera, Security Accessory
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
This is what an indoor security camera should be.
See your home 24/7 – in super-clear 1080p HD.
The Nest Cam Indoor security camera is designed to help you look after your home and family – even when you’re away.
With 24/7 live streaming, a versatile magnetic stand, person alerts with Nest Aware (sold separately) and one app for all your Nest products, Nest Cam Indoor helps you keep an eye on what matters. From anywhere.
Product Description Nest Cam Indoor - network surveillance camera
Device Type Network surveillance camera - fixed - indoor
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 7.3 cm x 7.3 cm x 11.4 cm
Weight 213 g
Colour Black
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Video Modes 1080p
Optical Sensor Type 1/3" - 3 MP
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, Bluetooth 4.0
Cables Included 1 - USB cable - external - 3 m
Voltage DC 5 V
Features Infrared cut filter, Smartphone Monitoring, cloud recording, magnetic mount
Environmental Parameters (operating) 0 °C - 40 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nest Cam Indoor Securi...
£129.00
