Nest Cam IQ Indoor Security Camera
FREE DELIVERY
£269.00
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Vision so visionary let's call it Supersight
  • Speaks loudly and carries a big microphone
  • Better connectivity
  • Person alerts
  • 4K sensor
  • Dual view
  • 3-microphone array
  • More powerful speaker
  • Noise and echo suppression
  • Type: Home security system, Indoor Camera
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (1)
SAVE ON GOOGLE HOME HUB WHEN BUYING WITH NEST CAM
= £317.99
Save £10.00
Nest Cam IQ has a 4K sensor, 12x digital zoom and gives you incredibly crisp, clear 1080p HD video. With HD Talk and listen you can have a conversation clearly. And Nest Cam IQ is thoughtful about when and how it alerts you. It has advanced algorithms that can identify when someone's in your home, alert your phone and then automatically follow that person as they move through the room. With a Nest Aware subscription, you can even receive a notification if it sees a friend or family member, or if it detects an unfamiliar person.
Product Description Nest Cam IQ - network surveillance camera
Device Type Network surveillance camera - fixed
Audio Yes: built-in speaker, two-way audio capability, built-in stereo microphone
Dimensions (WxDxH) 7.4 cm x 7.4 cm x 12.4 cm
Weight 357 g
Colour White
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Video Modes 1080p
Optical Sensor Type 1/2.5" - 8 MP
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac, Bluetooth LE
Cables Included 1 - USB cable - 3 m
Features Built-in antenna, infrared cut filter, auto tracking, High Dynamic Range (HDR)
Environmental Parameters (operating) 0 °C - 40 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nest Cam IQ Indoor Sec...
£269.00
