Nest Cam Outdoor Security Camera
FREE DELIVERY
£179.00
Select:
  • Single
18 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • 24/7 live video
  • Listen in and talk back
  • Install it yourself
  • Type: Home security system, Outdoor Camera, Security Accessory
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (1)
SAVE ON GOOGLE HOME HUB WHEN BUYING WITH NEST CAM
= £287.99
Save £10.00
Security, rain or shine. On your phone 24/7.
Standing watch 24/7. Rain or shine.
You don’t want a security camera that sleeps on the job, takes a rain check during a storm or makes your house look unwelcoming. Nest Cam Outdoor is beautiful, weatherproof and plugs into the mains power supply, so you never have to worry about dead batteries.
Alerts you when something happens.
You can’t always be watching your video feed. Nest Cam looks for motion and listens for loud sounds, like a boom or the crash of a window breaking. It can then alert you with a photo from the event, and can even save some of the pictures in the Nest app for three hours.
Talk & listen.
Nest Cam Outdoor has a built-in speaker and mic, so you can scare off a suspicious visitor when you’re out or ask the postman to leave your parcel at the door.
See what you’ve missed.
If you miss an alert, you can always see activity from the last three hours in the Nest app. So you’ll find out if someone was lurking on your doorstep and see a photo of them.
Product Description Nest Cam Outdoor - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor - weatherproof
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 7.2 cm x 8.9 cm x 7.2 cm
Weight 313 g
Colour White
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 30 frames per second
Video Modes 1080p
Optical Sensor Type 1/3" - 3 MP
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, Bluetooth 4.0
Cables Included 1 - USB cable - external
Voltage DC 5 V
Features Infrared cut filter, Smartphone Monitoring, cloud recording
Environmental Parameters (operating) -20 °C - 40 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nest Cam Outdoor Secur...
£179.00
