Nest Learning Thermostat - Black
FREE DELIVERY
£199.00
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Auto-Schedule
  • Auto-Away
  • Farsight
  • Remote control
  • Nest Leaf
  • Type: Thermostat
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (1)
CONTROL YOUR HEATING WITH YOUR VOICE
= £218.00
Save £30.00
Meet the 3rd gen Nest Learning Thermostat. It's slimmer and sleeker with a bigger, sharper display. And it saves energy. That's the most beautiful part.
Your thermostat controls half your energy bill - more than appliances, more than electronics. So shouldn't it help you save energy?
The 3rd gen Nest Learning Thermostat does. It learns what temperature you like and builds a schedule around yours.
Product Description Nest Learning Thermostat 3rd generation - thermostat
Product Type Thermostat
Sensor Type Temperature, humidity, ambient light
Functions Control heating systems, control cooling systems
Power Source Battery
Internet of Things (IoT) Platform Nest
Intelligent Assistant Google Assistant, Alexa - indirect
Connectivity Wireless - 802.11b/g/n, Bluetooth 4.0, 802.15.4
Supported Host Device OS iOS, Android
Thermostat 2.08" - LCD
Colour Black
Dimensions (WxDxH) 8.4 cm x 3.2 cm x 8.4 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nest Learning Thermost...
£199.00
