Meet the 3rd gen Nest Learning Thermostat. It's slimmer and sleeker with a bigger, sharper display. And it saves energy. That's the most beautiful part.
Your thermostat controls half your energy bill - more than appliances, more than electronics. So shouldn't it help you save energy?
The 3rd gen Nest Learning Thermostat does. It learns what temperature you like and builds a schedule around yours.
Product Description | Nest Learning Thermostat 3rd generation - thermostat | Product Type | Thermostat | Sensor Type | Temperature, humidity, ambient light | Functions | Control heating systems, control cooling systems | Power Source | Battery | Internet of Things (IoT) Platform | Nest | Intelligent Assistant | Google Assistant, Alexa - indirect | Connectivity | Wireless - 802.11b/g/n, Bluetooth 4.0, 802.15.4 | Supported Host Device OS | iOS, Android | Thermostat | 2.08" - LCD | Colour | Black | Manufacturer Warranty | 2-year warranty | Dimensions (WxDxH) | 8.4 cm x 3.2 cm x 8.4 cm |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.15 |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.9 or later |
Supported Host Device OS | Android 4.4 (KitKat) or later, iOS 10 or later |
Features | Wall mountable |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Platform | Nest |
Intelligent Assistant Compatible | Google Assistant, Alexa |
Voice Controlled | Indirect |
Thermostat | |
Modes | Auto, manual, programme |
Display | 2.08" - LCD |
Features | Backlit display |
Miscellaneous | |
Included Accessories | Mounting kit |
Colour | Black |
Battery Required | 1 Lithium Ion |
Dimensions & Weight | |
Width | 8.4 cm |
Depth | 3.2 cm |
Height | 8.4 cm |
Weight | 244 g |
