Nest Protect - Battery
FREE DELIVERY
£109.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Voice alarms with custom location
  • Low-battery, smoke, carbon monoxide and sensor failure alerts
  • Split-spectrum sensor
  • Nightly Promise function
  • Steam check
  • Wireless interconnect
  • Safety history and home report
  • Emergency shutoff
  • Emergency clip record
  • Type: Multipurpose sensor
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
The smoke alarm that thinks, speaks and alerts your phone.
Know more, worry less. The new Nest Protect looks for fast burning fires, slow, smoldering fires and invisible carbon monoxide. It speaks up to tell you what the problem is and where it is. It can also give you a friendly Heads­Up before it has to sound the alarm and you can hush it with your phone. In case you’re not home, Nest Protect alerts your phone when the alarm goes off or the batteries run low. It also gives you peace of mind by testing itself over 400 times a day and showing you everything’s working with a quick green glow when you turn off the lights. And it looks after your family for up to 10 years.
Product Description Nest Protect - 2nd Generation - multipurpose sensor
Product Type Multipurpose sensor
Sensor Type Temperature, humidity, ambient light, smoke, carbon monoxide, alarm, occupancy
Power Source Battery
Connectivity Wireless - 802.11b/g/n, Bluetooth 4.0, 802.15.4
Supported Host Device OS iOS, Android
Colour White
Localisation United Kingdom
Dimensions (WxDxH) 13.5 cm x 3.85 cm x 13.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£109.00
