The smoke alarm that thinks, speaks and alerts your phone.
Know more, worry less. The new Nest Protect looks for fast burning fires, slow, smoldering fires and invisible carbon monoxide. It speaks up to tell you what the problem is and where it is. It can also give you a friendly HeadsUp before it has to sound the alarm and you can hush it with your phone. In case you’re not home, Nest Protect alerts your phone when the alarm goes off or the batteries run low. It also gives you peace of mind by testing itself over 400 times a day and showing you everything’s working with a quick green glow when you turn off the lights. And it looks after your family for up to 10 years.
Product Description | Nest Protect - 2nd Generation - multipurpose sensor | Product Type | Multipurpose sensor | Sensor Type | Temperature, humidity, ambient light, smoke, carbon monoxide, alarm, occupancy | Power Source | Battery | Connectivity | Wireless - 802.11b/g/n, Bluetooth 4.0, 802.15.4 | Supported Host Device OS | iOS, Android | Colour | White | Localisation | United Kingdom | Manufacturer Warranty | 2-year warranty | Dimensions (WxDxH) | 13.5 cm x 3.85 cm x 13.5 cm |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.15 |
Supported Host Device OS | iOS 8.0 or later, Android 4.1 (Jelly Bean) or later |
Features | Night light, built-in microphone, built-in speaker, voice alarms, 6 colour LED, Heads-Up alerts, sound check, nightly promise, steam check, self-test, emergency shut-off, learning thermostat, home report |
Thermostat | |
Measurement Accuracy | ±1 °C |
Miscellaneous | |
Included Accessories | Screws, 6 AA batteries, backplate |
Colour | White |
Battery Required | 6 x AA type |
Compliant Standards | CSA, UL, NFPA 72, UL 2034, UL 217, EN 14604, EN 50291, EN 50271:2010, EN 50292 |
Dimensions & Weight | |
Width | 13.5 cm |
Depth | 3.85 cm |
Height | 13.5 cm |
Weight | 379 g |
Environmental Parameters | |
Min Operating Temperature | 4 °C |
Max Operating Temperature | 38 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
Sound Emission | 85 dB |
