Nest Protect - Wired
FREE DELIVERY
£109.00
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Get alerts on your phone
  • Every second counts
  • Tells you what and where
  • Type: Multipurpose sensor
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
The smoke alarm that thinks, speaks and alerts your phone.
Know more, worry less. The new Nest Protect looks for fast burning fires, slow, smoldering fires and invisible carbon monoxide. It speaks up to tell you what the problem is and where it is. It can also give you a friendly Heads­Up before it has to sound the alarm and you can hush it with your phone. In case you’re not home, Nest Protect alerts your phone when the alarm goes off or the batteries run low. It also gives you peace of mind by testing itself over 400 times a day and showing you everything’s working with a quick green glow when you turn off the lights. And it looks after your family for up to 10 years.
It’s time to expect more from your smoke alarm.
Nest Protect has been redesigned from the inside out. It has a Split-Spectrum Sensor, tests itself automatically and lasts for up to a decade. It's also the first home alarm that you can silence from your phone without any extra hardware required. And it tells you what's wrong and can even alert your phone.
Meet the Nest Protect. The smoke alarm that other alarms look up to.
Thinks before it speaks.
Nest Protect has a friendly human voice that gives you an early warning. That way you can handle burning toast before it becomes a burning toaster.
Tells you where the danger is.
And when one speaks, they all speak. So the alarm in your bedroom can tell you there’s smoke downstairs.
10-year CO sensor.
Carbon monoxide is poisonous, but you can’t see it or smell it. That’s why Nest Protect has a long-lasting carbon monoxide sensor that keeps working for up to a decade.
Tests itself: You’re supposed to test smoke alarms monthly. But most people don’t. So Nest Protect checks its batteries and sensors over 400 times a day. And it’s the first alarm that uses Sound Check to quietly test its speaker and siren once a month.
Lights your way: If you need a glass of milk in the middle of the night, Nest Protect lights up as you walk underneath it. Pathlight is one of our customers' favourite features, so we've made it better and brighter.
Steam is not smoke: Has your alarm ever yelled at you for having a shower? Nest Protect comes with Steam Check. It uses custom algorithms and a humidity sensor to look for steam so that you can enjoy a nice, quiet shower.
This is going to be easy.
You can set up your Nest Protect in just minutes using your iPhone, iPad or Android device.
Product Description Nest Protect 2nd Generation - multipurpose sensor
Product Type Multipurpose sensor
Sensor Type Temperature, humidity, ambient light, smoke, carbon monoxide, alarm, occupancy
Power Source Battery
Connectivity Wireless - 802.11b/g/n, Bluetooth 4.0 LE, 802.15.4
Supported Host Device OS iOS, Android
Colour White
Dimensions (WxDxH) 13.5 cm x 3.85 cm x 13.5 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£109.00
