Nest Thermostat E
FREE DELIVERY
Nest Thermostat E
£199.00
Delivery:
Standard: 1-3 working days
Express: Delivered on Friday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Designed to go unnoticed
  • Helps save energy and keeps you comfortable
  • Type: Thermostat
  • Compatible With: Alexa, Google Assistant, Nest
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GOOGLE NEST HUB SMART DISPLAY
= £238.00
Save £40.00
CONTROL YOUR HEATING WITH YOUR VOICE
= £218.00
Save £30.00
It’s easy to save energy.
Meet the Nest Thermostat E.
Turn it up or down from anywhere.
You can change the temperature with the Nest app on your phone, tablet or laptop.(1) Or just use your voice with your home assistant.(2)
It saves energy. And keeps you cosy.
The Nest Thermostat E is all set with a simple schedule to help you save from day one.(3) It knows when everyone has left the house, then turns itself down so that you're not heating an empty home. And when you change to an energy-saving temperature, you'll see the Nest Leaf.
Meet the Heat Link E.
The Heat Link E connects to your heating system and works with the Nest Thermostat E to turn on and off or modulate the heat. It can also sense the temperature in the room.
It blends in beautifully.
The frosted display shows you the temperature when you’re up close, then it all disappears when you walk away. And you can place the Nest Thermostat E on a table or desk in a room that matters most.
It’s easy to install yourself.
Most people install the Nest Thermostat E in 60 minutes or less, because you don’t need to access your heating system. The Heat Link E goes in the same spot as your current wired thermostat. And you can put the Nest Thermostat E anywhere you like.
In The Box
  • Nest Thermostat E
  • Heat Link E
  • Power adapter
  • Trim plate
  • Screws
  • Terminal blocks
  • Quick start guide
  • Welcome guide
  • Warranty
(1) Mobile notifications and remote control require working Internet and Wi-Fi.
(2) Voice commands require a compatible home assistant.
(3) Energy savings are not guaranteed and depend on energy usage, weather and other factors. Learn more at nest.com/eu/savings.
Product Description Nest Thermostat E - thermostat
Product Type Thermostat
Sensor Type Temperature, humidity, ambient light, occupancy, proximity
Functions Control heating systems, control cooling systems
Power Source Battery
Connectivity Wireless - Bluetooth, 802.11b/g/n, 802.11a/n, 802.15.4
Frequency Band 2.4 Ghz, 5 GHz
Supported Host Device OS iOS, Android
Thermostat 1.76" - LCD
Colour White
Manufacturer Warranty 1-year warranty
ENERGY STAR Certified Yes
Dimensions (WxDxH) 8.1 cm x 2.89 cm x 8.1 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Nest Thermostat E
£199.00
