Netatmo Additional Smart Radiator Valve
£64.99
Delivery:
Key features
  • Save even more energy
  • Open window detection
  • Smart regulation
  • Manual boost
  • Easy set-up
  • Type: Radiator thermostat
  • Compatible With: Siri
Product codes
Netatmo additional smart radiator valve
Complete your Thermostat with Netatmo Smart Radiator Valves and take control of all your individual radiators. Works with Netatmo Smart Thermostat.
Thanks to the room-by-room schedule based on your daily routine, heat according to individual room use and save even more energy.
Room-by-room comfort
Fine-tune your comfort temperature room-by-room.
Smart heating in your home
Open Window Detection - When the Smart Radiator Valve detects a window is open, it switches off the heating in the room to prevent energy waste. Available soon.
Smart Regulation - The Smart Radiator Valve analyzes the room environment in real time and adjusts heating according to sunshine level and room use.
Manual Boost - When needed, the temperature can be temporarily raised in a specific room for 3 hours.
Easy set-up - Replace your current thermostatic valves with ease even when the radiators are heating. No specific knowledge required. Water cannot leak during installation.
Your current situation
Thermostatic valves:
Replace your current thermostatic valves in two steps. Thermostatic valve have numbered graduation marks (usually from 1 to 5).
1. Remove the current thermostatic radiator valve.
2. Place the new Netatmo Smart Radiator Valve.
Manual valves:
Manual radiator valves simply switch the heating on or off and do not have numbered graduation marks (standard marks usually range from 1 to 5). To replace manual valves, contact a professional.
Product Description Netatmo Additional Smart Radiator Valve - water valve
Product Type Water valve
Power Source Battery
Connectivity Wireless
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Netatmo Additional Sma...
£64.99
