Netatmo Healthy Home Coach
£89.98
Delivery:
Product codes
Netatmo healthy home coach
The Smart Indoor Climate Monitor. Works with Apple Homekit.
Act for a healthier home
You want to provide the healthiest home possible for your family. Netatmo’s Healthy Home Coach shows you how. Whether it’s the best noise level for sound sleeping or the right humidity levels for a child with asthma, Healthy Home Coach measures what matters, highlights potential problems, and tells you how to fix them.
Know if your home is healthy or not with a single glance at your smartphone.
Healthy Home Coach tells you what you need to adjust to create a healthier environment from your baby to your asthmatic child to you.
4 precise sensors
HUMIDITY - Avoid excessive humidity in your house.
Dry air can cause itchy skin. Humid air can lead to the growth of mold. And humidity levels can play a huge role in managing asthma and allergies. Find the balance that works best for each room of your home.
AIR QUALITY - Learn how to reduce indoor air pollution.
A poorly ventilated room leads to high indoor air pollution. It also tremendously reduces your ability to concentrate, which is key when your teens are doing their homework or preparing exams.
NOISE - Monitor the sound level to achieve a good night’s sleep.
Often a disturbed sleep might be caused by noises you don’t realize you heard. Check the data history of your family sleep time to understand how you can improve their sleep.
TEMPERATURE - Make sure the temperature is right for you, day and night.
Your baby and toddler are not able yet to balance their body temperature properly. You might find them waking up from naptime all sweaty while you were sure the room temperature was comfortable.
Multi-room
Connect several Healthy Home Coache devices to monitor all your rooms in one App.
Easy on the eyes, easy to use.
ELEGANT DESIGN - Sleek and elegant, Healthy Home Coach blends easily with any home’s décor.
REMOTE ACCESS - Just log in using our app and access your home’s indoor climate from anywhere.
SET UP - Easy Wi-Fi set up. No subscription, no fees.
ASK SIRI HOW HEALTHY YOUR HOME IS - Works with Apple Homekit.
EASY TO USE - With just one tapon the top, Healthy Home Coach lights up to give you immediate insight into the health of your home.
EASILY EXPANDABLE - Monitor better your home by placing a Healthy Home Coach in each room that matters in your family life.
Netatmo Healthy Home Coach - anemometer
Anemometer
Wireless
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Netatmo Healthy Home C...
£89.98
