Netatmo Smart Outdoor Camera with Siren
£319.00
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Immediate trespassing notifications sent to your smartphone
  • Deter intruders with a 105-dB alarm
  • With the Alert-Zones feature, receive only useful alerts
  • A built-in smart lighting system for even greater efficiency
  • Free upgrades, with no subscription
  • Data stored and secured locally on microSD card
  • Images accessible 24 hours a day from your smartphone
  • Replaces an existing light for easy installation
  • Wear and weather resistant - a camera made to last
  • Type: Motion sensor, Outdoor Camera, Siren
  • Compatible With: Alexa, Google Assistant, Siri
  • Stock Status: In Stock
Product codes
Adapted notifications: enjoy peace of mind in real time
Your Netatmo Outdoor Camera protects your home and offers you peace of mind. When it detects an unknown person or vehicle on your property, it immediately sends a notification to your smartphone. Your Smart Camera can distinguish between people, animals, cars and harmless movements. You can take action as soon as you receive an alert.
Deter intruders with a 105-dB alarm.
Prevent burglaries with your Smart Outdoor Camera and its built-in siren. When a person or vehicle enters your property, you will immediately receive an alert and a video on your smartphone. Is it an intruder? Deter them by triggering the siren and its deafening 105-dB alarm directly from your app.
No more false alarms
Set up your Outdoor Camera to receive only useful alerts. Use the Alert-Zones feature to define the areas you want to monitor and the type of intrusion you want to know about. People, vehicles, animals? Set your preferences as you see fit.
Camera equipped with a smart lighting system
Your Outdoor Camera is equipped with a built-in smart lighting system. During an alert, a floodlight is activated to help deter intruders. Choose manual activation using the app or automatic switch-on. The system can also light your path at night.
Access to all features, and no subscription necessary
No ties! Videos and their storage along with all camera-related features are fully accessible without subscription. App upgrades and additions are free and will stay that way.
Fully secured data
With Netatmo, your data is always secure. Opt for local video storage on a microSD card using high-security encryption combined, if you wish, with automatic backup to the cloud via Dropbox or your FTP server.
Keep in touch with home
Keep in touch with home while you’re away. Images captured by your Netatmo Outdoor Camera are accessible 24/7 via the app. Even more reassuringly, your Outdoor Camera is equipped with infrared vision, so it works equally well at night.
Voice command and integration with other connected devices
Your Outdoor Camera has hidden talents! If you’re comfortable with technology, create scenarios with other smart devices via Apple HomeKit, and use voice control to take advantage of Siri, Alexa and Google Assistant compatibility.
Quick to install
Your Outdoor Camera is easy to install. Replace an existing light or select a strategic location to monitor your home. Then connect it to your Wi-Fi to control it remotely and enjoy all its features!
Long-lasting equipment
Designed to last! Your Netatmo Outdoor Camera will stand the test of time. Made of highly resistant UV-protected aluminum, glass and plastic, and compliant with HZO weatherproofing standards, your camera withstands the elements.
Box Contents
Mounting kit
Wall mount
MicroSD card
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Netatmo Smart Outdoor...
£319.00
