Netatmo Smart Thermostat
£149.98
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Energy savings
  • Control your heating remotely
  • Right temperature at the right time
  • Auto-adapt function
  • Auto-care function
  • Type: Thermostat
  • Compatible With: Alexa, Google Assistant, Siri
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GOOGLE NEST HUB MAX
GOOGLE NEST HUB MAX
= £298.98
Save £20.00
NEST MINI
NEST MINI
= £169.98
Save £3.99
Netatmo smart thermostat
37% less energy on average to heat your home
Use your Netatmo Thermostat to change your home's temperature, from your bed or from the other side of the world.
Schedule your heating for your return from a holiday.
The Thermostat uses your answers to 5 questions to create a schedule that’s based on your habits and lifestyle, so you only use the heating when you need it.
Smart heating in your home
Auto-Adapt function
The Netatmo Thermostat’s Auto-Adapt function uses your home’s insulation and the outdoor temperature to programme when your heat should switch on. So you can have the temperature you want at just the right time.
Auto-Care function
Thanks to its Auto-Care function, the Netatmo Thermostat can tell you when its batteries are low, or notify you of a problem with your heating system’s operation.
Control your heating using just your voice
Apple Homekit: "Siri, set my thermostat to 20°C"
Amazon Alexa: "Alexa, decrease my thermostat temperature by 3°C"
Google Assistant: "Ok Google, set the thermostat to 21 degrees'"
Receive our money-saving tips
Every month, you receive your customised Energy Savings Report. The report will help you track your consumption and adjust your heating schedule for optimal savings.
Track your consumption
Display your past energy consumption.
Your indoor temperature and boiler activity are recorded continuously in the App.
Product Description Netatmo smart thermostat - by Stark - thermostat
Product Type Thermostat
Environment Indoor
Functions Temperature measuring, control heating systems
Power Source Battery
Intelligent Assistant Siri, Google Assistant, Alexa - indirect
Connectivity Wireless - 802.11b/g/n
Frequency Band 2.4 Ghz
Supported Host Device OS iOS, Android, Windows Phone
Thermostat E Ink
Localisation Europe
Dimensions (WxDxH) 8.3 cm x 2.2 cm x 8.3 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£149.98
