Netatmo smart thermostat
37% less energy on average to heat your home
Control your heating remotely
Use your Netatmo Thermostat to change your home's temperature, from your bed or from the other side of the world.
Schedule your heating for your return from a holiday.
Right temperature at the right time
The Thermostat uses your answers to 5 questions to create a schedule that’s based on your habits and lifestyle, so you only use the heating when you need it.
Smart heating in your home
Auto-Adapt function
The Netatmo Thermostat’s Auto-Adapt function uses your home’s insulation and the outdoor temperature to programme when your heat should switch on. So you can have the temperature you want at just the right time.
Auto-Care function
Thanks to its Auto-Care function, the Netatmo Thermostat can tell you when its batteries are low, or notify you of a problem with your heating system’s operation.
Control your heating using just your voice
Apple Homekit: "Siri, set my thermostat to 20°C"
Amazon Alexa: "Alexa, decrease my thermostat temperature by 3°C"
Google Assistant: "Ok Google, set the thermostat to 21 degrees'"
Receive our money-saving tips
Every month, you receive your customised Energy Savings Report. The report will help you track your consumption and adjust your heating schedule for optimal savings.
Track your consumption
Display your past energy consumption.
Your indoor temperature and boiler activity are recorded continuously in the App.
Product Description | Netatmo smart thermostat - by Stark - thermostat | Product Type | Thermostat | Environment | Indoor | Functions | Temperature measuring, control heating systems | Power Source | Battery | Intelligent Assistant | Siri, Google Assistant, Alexa - indirect | Connectivity | Wireless - 802.11b/g/n | Frequency Band | 2.4 Ghz | Supported Host Device OS | iOS, Android, Windows Phone | Thermostat | E Ink | Localisation | Europe | Dimensions (WxDxH) | 8.3 cm x 2.2 cm x 8.3 cm |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Max Range Open Space | 100 m |
Supported Host Device OS | Android 4.2 (Jelly Bean) or later, iOS 9 or later |
Features | 2 years battery lifetime, Auto-Adapt function, Auto-Care function, switching current up to 4 A, switching voltage up to 250 VAC |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Internet of Things (IoT) Hub | Included |
Internet of Things (IoT) Hub Compatibility | Netatmo Relay |
Intelligent Assistant Compatible | Siri, Google Assistant, Alexa |
Voice Controlled | Indirect |
Thermostat | |
Temperature Range | 5 - 30 °C |
Measurement Accuracy | ±0.5 °C |
Modes | Auto, programme |
Display | E Ink |
Features | Multi-zone |
Miscellaneous | |
Included Accessories | Power adapter, wall mount, stand, USB cable, 3 AAA batteries, boiler adapter, screws, mounting plate, 4 colour adhesives, relay |
Product Material | Plexiglas |
Encryption Algorithm | AES, TKIP, WPA, WPA2, WEP |
Battery Required | 3 x AAA type |
Dimensions & Weight | |
Width | 8.3 cm |
Depth | 2.2 cm |
Height | 8.3 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
