NETGEAR 10Pt Multi Gb Poe+ Smart Switch
£332.61
Delivery:
Standard: 1-3 working days
Key features
  • Multi-Gigabit, multi-speed ports to connect any type of device to a single switch
  • Quiet desktop operation or rack mounting
  • Layer 3 static routing with 32 routes for interVLAN local routing
  • Advanced VLAN support for better network segmentation
  • Advanced QoS for traffic prioritization including port-based, 802.1p and L2/L3/L4 DSCP-based
  • Auto "denial-of-service" (DoS) prevention
  • IGMP Snooping and Querier for multicast optimization
  • Rate limiting and priority queuing for better bandwidth allocation
  • Port mirroring for network monitoring
  • Energy Efficient Ethernet (IEEE 802.3az) for maximum power savings
  • Easy-to-use web browser-based management GUI
  • SNMP v1, v2c, v3 and RMON remote monitoring
  • Standards-based technology ensures interoperability with any standards-based devices in the existing network
  • Dual firmware images improve reliability and uptime to your network
Product codes
Each port automatically detects which speed is needed by the connected device and provides the adequate speed. As opposed to regular 10-Gigabit switches that will only provide 1-Gigabit connectivity to any device that require less than 10-Gigabit, the switch gives the exact speed required, with no downgrade. Also, the NETGEAR Multi-Gigabit switch ports can connect regular CAT5e Ethernet cables, without the need to upgrade to CAT6 wiring, therefore reducing wiring costs and hassle. Access, aggregation or collapsed core: you can now have your PCs, printers and routers/firewalls connected at 1G and aggregate Multi-Gigabit Ethernet devices on the same switch, all line-rate. 10G copper and fiber ports are ready for local servers and storage, or high-speed aggregation to your network core.
NETGEAR MS510TXPP - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - L3 Lite - smart
Enclosure Type
Rack-mountable
Subtype
10 Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 2 x 100/1000/2.5G/5G (PoE+) + 2 x 100/1000/2.5G (PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
180 W
Performance
Bandwidth: 78 Gbps , Latency (10 Gbps): <2.36µs , Latency (SFP+): <2.6µs , Packet forwarding rate: 58 Mpps
LAG groups: 8 , MAC addresses: 16000 , ACL entries (ingress): 164 , Virtual interfaces (VLANs): 256 , RP/NDP table: 512 , IPv4 routes (static): 32 , IPv6 routes (static): 32 , IGMP multicast groups: 512 , ARP entries: 512 , VLAN routing interfaces: 32 , Jumbo frame size: 10000 , DHCP snooping entries: 1000 , Multicast groups: 512 , Priority queues: 8
MAC Address Table Size
16K entries
Routing Protocol
Static IP routing
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c
IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, Dynamic ARP Inspection (DAI), LACP support, LLDP support, Energy Efficient Ethernet, Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, 1.5MB packet buffer, MAC and IP-based ACLs support, 1 fan, Voice VLAN, VLAN management, Guest VLAN, Weighted Round Robin (WRR), Auto VoIP, MAC lockdown, IPv6 management
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az, ITU-T H.323, IEEE 802.3bz
32.8 cm x 16.9 cm x 4.3 cm
1.9 kg
Europe
ProSAFE lifetime warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 10Pt Multi Gb...
£332.61
