NetGear 12-Port Gigabit Fiber Layer 2 Managed Switch
£684.43
Delivery:
Standard: 1-3 working days
Key features
  • High-speed, Layer 2 managed gigabit switching
  • Easy to use
  • Outstanding value
  • Type: Gigabit Ethernet
  • Ports: 12
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: PoE
Product codes
Typical campus, warehouse or large building IP telephony, Wireless or Video-Surveillance deployments require flexible and affordable Fiber aggregation.
This 12-port Fiber platform with 12 combo Gigabit ports, provide PoE+ as well – whenever and wherever you want – even far from the MDF or typical wiring closet.
Because PoE deployments are always restrained by 100-meter copper limitation, such low-port count Fiber solution will simplify architectures and even power local PoE+ devices.
Product Description NETGEAR M4100 M4100-12GF - switch - 12 ports - Managed - rack-mountable
Device Type Switch - 12 ports - L2+ - Managed - stackable
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 12 x combo Gigabit SFP + 4 x 10/100/1000
Power Over Ethernet (PoE) PoE
Performance Switching capacity: 24 Gbps , Throughput: 17.8 Mpps
MAC Address Table Size 8K entries
Jumbo Frame Support Yes
Routing Protocol Static IP routing
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Features VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
Compliant Standards IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
Dimensions (WxDxH) 44 cm x 20.5 cm x 4.3 cm
Weight 3.7 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear 12-Port Gigabi...
£684.43
