NETGEAR 16 Port Gigabit Compact Switch
£78.79
14 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 16 high-speed, auto-sensing 10/100/1000 Mbps Ethernet connections
  • Integrates 10, 100 and 1000 Mbps devices within a network
  • Silently delivers up to 2000 Mbps on each port
  • Type: Gigabit Ethernet
  • Ports: 16
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
Now you can have a powerful, high-speed network on a small scale. NETGEAR's GS116 Gigabit Ethernet Switch lets you build a system that provides a full, dedicated 1000 Mbps connections so you can move very large files across your network instantly. The standards-based GS116 helps to protect your existing and future network infrastructure investments by painlessly integrating other 10,100, and 1000 Mbps devices. This potent switch is ideal for workgroups or quickly upgrading workstations to full Gigabit speed, plus it's packed with ease-of-use features to simplify your workday experience. Its compact design fits neatly into small work spaces and, since it's self-cooling without a fan, it runs silently and unobtrusively.
Product Description NETGEAR GS116 16 Port Gigabit Desktop Switch - switch - 16 ports
Device Type Switch - 16 ports
Subtype Gigabit Ethernet
Ports 16 x 10/100/1000
MAC Address Table Size 8K entries
Features Full duplex capability, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p
Dimensions (WxDxH) 28.5 cm x 10.3 cm x 2.7 cm
Weight 0.9 kg
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 16 Port Gigabi...
£78.79
