NetGear 16-Port Gigabit Ethernet Unmanaged Desktop Switch
£71.67
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • LED indicators for ease of use
  • Energy-efficient technology for power savings
  • Fanless design for silent operation
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Non-blocking switching architecture for maximum throughput at wire speed
  • 802.1p QoS for traffic/frame prioritization
  • Plug-and-play; no setup required
  • Durable and rugged metal case
  • Ideal for small office and home networks
  • Standards-based technology ensures interoperability with any standards-based devices in the existing network
  • Type: Gigabit Ethernet
  • Ports: 16
  • Managed: No
  • Stock Status: In Stock
Product codes
The NETGEAR 16-Port Gigabit Ethernet Switch with simple plug-and-play, compact desktop design, and auto-sensing ports provides easy, reliable, and affordable connectivity for your home or small office network. A rugged metal enclosure, silent, fanless design, and wall mount kit allow for convenient deployment to build out your SOHO network. Auto-MDI/MDIX (eliminating the need for crossover cables), jumbo packet support, auto-negotiation for automatic connection at highest speeds, non-blocking switching architecture for maximum throughput, and energy-efficient technology for power savings (IEEE 802.3az and short cable power reduction) make the GS316 the perfect switch for the SOHO environment.
Product Description NETGEAR SOHO GS316 - switch - 16 ports - unmanaged
Device Type Switch - 16 ports - unmanaged
Subtype Gigabit Ethernet
Ports 16 x 10/100/1000
Performance Bandwidth: 32 Gbps , Forwarding performance (64-byte packet size): 1448000 packets per second , Latency (64-byte packets): 3.9 µs
MAC Address Table Size 2K entries
Jumbo Frame Support 9270 bytes
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), fanless, 768KB packet buffer, Energy-Efficient Ethernet (EEE)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Dimensions (WxDxH) 28.6 cm x 10.1 cm x 2.6 cm
Weight 840 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear 16-Port Gigabi...
£71.67
