NetGear 16Port Gigabit Smart Switch
£100.54
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Designed for converged network, big or small
  • Gigabit speed with non-blocking architecture supporting 100% Gigabit throughput
  • Auto Voice VLAN for fast and reliable deployment of VoIP
  • Auto Video VLAN, following the same concept of Auto Voice, helps speed up your deployment of IP-based surveillance system
  • Static routing, helps to route internal traffic for more efficient use of network resources
  • IGMP and MLD snooping, providing advanced multicast filtering
  • Type: Gigabit Ethernet
  • Ports: 16
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: No
Product codes
The NETGEAR ProSAFE Gigabit Smart Managed switches offer powerful Layer 3 Lite features with enhanced performance and usability. They are purposely designed for the future where increased traffic and application-oriented tasks demands more intelligence at the edge, higher reliability and improved network efficiency on top of operational cost savings and ease of management.
Product Description NETGEAR GS716T 16-Port Gigabit Smart Managed Switch - switch - 16 ports - Managed - rack-mountable
Device Type Switch - 16 ports - L3 Lite - Managed
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 16 x 10/100/1000 + 2 x Gigabit SFP
Performance Bandwidth: 36 Gbps
Capacity Virtual interfaces (VLANs): 256 , ACL entries: 100 , Static routes: 32 , Layer 2 multicast groups: 512 , ARP entries: 512 , Priority queues per port: 8
MAC Address Table Size 16K entries
Jumbo Frame Support 9KB
Routing Protocol IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, HTTPS, TFTP
Features Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, MLD snooping, Dynamic ARP Inspection (DAI), LLDP support, DHCP client, Energy Efficient Ethernet, Strict Priority Queuing (SPQ), static routing, 802.1x authentication, Type of Service (ToS), VoIP support, DiffServ Code Point (DSCP) support, cable test, administrator's password, ARP inspection
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
Dimensions (WxDxH) 44 cm x 20.4 cm x 4.3 cm
Weight 2.57 kg
Localisation Europe
Manufacturer Warranty NETGEAR lifetime warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear 16Port Gigabit...
£100.54
