NetGear 24-Port Gigabit PoE Layer 2 Managed Switch
£616.30
Delivery:
Standard: 1-3 working days
Key features
  • Powerful
  • Easy to use
  • Manageable
  • Outstanding performance
  • Type: Gigabit Ethernet
  • Ports: 24
  • Data Transfer Rate: 1Gbps
  • Managed: Yes
  • POE: PoE+
Product codes
IP telephony, Wireless or Video-Surveillance deployments may require higher PoE+ density in wiring closets. This 24-port PoE+ platform is 802.3af full power – with supplemental 802.3at full power capacity – yet affordable when compared to typical competitive solutions with even less PoE budget. When associated to GSM7212F, PoE deployments can be much Smarter with the right number of PoE ports – whenever and wherever you want.
Product Description NETGEAR ProSAFE GSM7224P - switch - 24 ports - Managed - rack-mountable
Device Type Switch - 24 ports - L2+ - Managed - stackable
Enclosure Type Rack-mountable 1U
Subtype Gigabit Ethernet
Ports 24 x 10/100/1000 (PoE+) + 4 x shared SFP
Power Over Ethernet (PoE) PoE+
Performance Switching capacity: 48 Gbps
MAC Address Table Size 8K entries
Jumbo Frame Support Yes
Routing Protocol Static IP routing
Remote Management Protocol SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Features VLAN support, DiffServ support, IPv6 support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), Jumbo Frames support, DHCP server, PoE+, IPv4 support, Link Aggregation Control Protocol (LACP), DHCP client
Compliant Standards IEEE 802.3af, IEEE 802.1x, IEEE 801.1p
Dimensions (WxDxH) 44 cm x 20.5 cm x 4.3 cm
Weight 3.7 kg
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear 24-Port Gigabi...
£616.30
