NETGEAR 48 Port GigE Unmanaged Rackmount Switch
FREE DELIVERY
£216.56
Delivery:
Standard: 1-3 working days
Key features
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • LED indicators for ease of use
  • Energy-efficient technology for power savings
  • Fanless design for silent operation
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Non-blocking switching architecture for maximum throughput at wire speed
  • 802.1p QoS for traffic/frame prioritization
  • Plug-and-play; no setup required
  • Durable and rugged metal case
  • Ideal for small office and home networks
  • Standards-based technology ensures interoperability with any standards-based devices in the existing network
  • Rack-mountable (rackmount kit included)
  • Type: Gigabit Ethernet
  • Ports: 48
  • Managed: No
  • Stock Status: In Stock
Product codes
NETGEAR 300 Series Gigabit Ethernet Unmanaged Switches provide easy, reliable, and affordable network connectivity for home and small offices. With these unmanaged plug-and-play switches, you can expand your network connections to multiple devices instantly.
Product Description NETGEAR SOHO GS348 - switch - 48 ports - unmanaged - rack-mountable
Device Type Switch - 48 ports - unmanaged
Enclosure Type Rack-mountable
Subtype Gigabit Ethernet
Ports 48 x 10/100/1000
Performance Bandwidth: 96 Gbps , Forwarding performance (64-byte packet size): 1448000 packets per second , Latency (64-byte packets): 4 µs
MAC Address Table Size 16K entries
Jumbo Frame Support 9216 bytes
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), fanless, 1.5MB packet buffer, Energy-Efficient Ethernet (EEE)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V (50 - 60 Hz)
Dimensions (WxDxH) 44 cm x 20.4 cm x 4.32 cm
Weight 3.15 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NETGEAR 48 Port GigE U...
£216.56
