NetGear 5-port Gigabit Ethernet Switch
£17.77
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • LED indicators for ease of use
  • Energy-efficient technology for power savings
  • Fan-less design for quiet operation
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Non-blocking switching architecture for maximum throughput at wire speed
  • Plug-and-play
  • High-performance metal case
  • LED on each port
  • Wall mountable
  • Type: Gigabit Ethernet
  • Ports: 5
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: No
Product codes
These NETGEAR home Ethernet switches provide an easy, reliable, and affordable way to expand your network connections in homes and small offices.
High-performance metal case provides easy, reliable and affordable Gigabit Ethernet connection for your home network. Features include auto-MDI/MDIX (eliminating the need for crossover cables) and LED indicators for ease of use. Energy-efficient technology provides power savings.
Product Description NETGEAR GS305 - Essentials Edition - switch - 5 ports - unmanaged
Device Type Switch - 5 ports - unmanaged
Subtype Gigabit Ethernet
Ports 5 x 10/100/1000
Performance Bandwidth: 10 Gbps
MAC Address Table Size 2K entries
Jumbo Frame Support 9216 bytes
Features Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), metal housing
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Power AC 120/230 V (50/60 Hz)
Dimensions (WxDxH) 10.2 cm x 9.4 cm x 2.6 cm
Weight 240 g
Localisation United Kingdom
Manufacturer Warranty 2 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
NetGear 5-port Gigabit...
£17.77
